Can i use aircraft manuals on my iPhone?
CoOoOoL
Dec 2, 2007
60
dear all:
Can i use aircraft manuals in my iPhone?
is there app i need to download?
Can you provide any links?
Thank you!
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
dear all:
links please?
thank you
If you gave a bit more information on the format of the manuals we can probably help. If your phone is jailbroken there are two possible programs that can work to allow you to read documents on the phone easily. They are the PDF reader and the Book application. The book application allows you to read text files and htm documents saved to the phone. The PDF reader allows reading PDFs, duh. :laugh2:
CoOoOoL
Dec 2, 2007
60
it's adobe , dear
termleech
Sep 7, 2007
1,154
McPherson, KS
You can download and install the PDF viewer program from installer.app. that's assuming you have jailbroken your phone and call install third party apps. Then you can upload the PDF's to the phone using SSH.
geordisjd
2,442
dear all:
links please?
thank you
If you're not jailbroken, you can put the manual on your website and Safari will open it. In fact, you can even email yourself a pdf file from your computer, click it on the iPhone and Safari will open it too. If you can access your computer from your iPhone with iPhone Remote (Mac)/ Orb-I think (PC), then you can open any of your computer's compatible files (including pdf) directly on your iPhone.
CoOoOoL
Dec 2, 2007
60
thank you dear for your time and help
thank you again
and i wish you happy life
CoOoOoL
Dec 2, 2007
60
thank you again
and i wish you happy life;)
