Can I use MMS on a different phone using iPhone SIM card?
phillyphill39
Dec 30, 2007
146
Has anyone been able to use the MMS feature on another AT&t device, using their iPhone sim card?
hinzy
Feb 6, 2008
72
i believe it will work if you have a family text plan or have "pay per use" on your account.
phillyphill39
Dec 30, 2007
146
nah no family txt plan just have 1 number. because the data/txt plan for the iPhone has the mms included into the package.
hinzy
Feb 6, 2008
72
no... the iPhone data plan does NOT include mms.
phillyphill39
Dec 30, 2007
146
It's included in the unlimited messaging plan, but just not provisioned to be used. I was trying to see if anyone has gotten it work or found a work around. But the MMS feature is there.
hinzy
Feb 6, 2008
72
you don't have a "regular" unlimited messaging plan. You have a iPhone data and messaging plan which isn't set up for MMS.
They are two different plans.
If there is a work around... i would like it too!
phillyphill39
Dec 30, 2007
146
O MME0 UCFME EXPANDED M2M 12/24/2007 O RM450 ROLEX Rollover Minutes 12/24/2007 R MMV3 MMVBUN VVM Media Bundle 12/24/2007 N A4N1J AMMS Multimedia Messaging 12/24/2007 N A4N1J ASMS Text/Instant Msgs 12/24/2007 N H988 H988 Data feature for MMV 12/24/2007 N IPVV IPVV VISUAL VM POSTPD 12/24/2007 N MBRH AWIX INTERNET XPRESS 12/24/2007 R 1APL GNRL GENERAL 12/24/2007 R BKUP BKUP AT&T Mobile Backup 02/07/2008 R MSG1 MMS Multimedia Messaging 02/07/2008 R MSG1 SMSNOW Text Messaging 02/07/2008
Its there just don't know what that A means. don't look at the 1 below that, that was of course just added today. But the other one that says AMMS
phillyphill39
Dec 30, 2007
146
But anyways im just trying to figure it out, there has to be a way. because i can use my other phone for data just fine, and im not being charged extra. it looks like im using my iPhone when im actually not.
hinzy
Feb 6, 2008
72
I know it's possible to get because it does work if you have family messaging or pay per use. I spent hours on the phone with AT&T trying to get it turned on so i could send with my other phone or with swirlyMMS and they said i couldn't get unlimited unless it was family plan but i did get pay per use on my account and that does work.
phillyphill39
Dec 30, 2007
146
When you check your bill on the net, does it should when you have sent/received an MMS and if so about long after you sen/received it does it take for it show up?
hinzy
Feb 6, 2008
72
I only used it a couple times to see if it worked. Are you asking how long it took for the person to receive it, or are you asking how long it took to show on the bill?
The person received it instantly just like any other time.
As soon as i found out i was getting charged per message i just went to using strictly email to send photos to people.
phillyphill39
Dec 30, 2007
146
Like how long it took to show up on the bill. Because you can see your data usage on your bill and shows up almost instantly. For some reason im able to add/drop features off of my bill now. Yesterday i couldnt, so i added the 200 mms/sms plan. And then took it off, because at the bottom
hinzy
Feb 6, 2008
72
I never looked to see if it got billed right away. I'm borrowing out my other phone to a friend right now or i could check.
I would be careful adding certain things to your iPhone plan. A while back i thought i would be tricky and go with the $20 Data Plan and then get the Messaging Unlimited plan that is offered for other phones thinking i could then have unlimited texts and also be able to send MMS when my card was using my other phone (just like how the family text plan works) but the Messaging Unlimited plan cancelled out my data plan without me knowing it and i was getting charged for data.
