Can not enable call waiting
FunnyMan
Jul 15, 2007
When I go into Settings > Phone > Call Waiting and try to turn it on I'm getting "Could not Save Call Waiting Setting and a Dismiss button.
Anyone else having that problem?
Anyway to solve that?
DeadSpider
120
41
Vacherie,Louisiana
No problems here. I swapped back and forth just incase.
Just asking, does it still do this after a reset?
FunnyMan
Jul 15, 2007
That's odd.
I was about to tell you that a reset didn't do it (because I obviously tried resetting it), but after one other reset, it finally worked!
Now it has another weird issue: Sometimes it shuts itself off, even though the battery is only half empty.Can I replace the battery? Is there a way to fix this myself?
Thanks!
