can someone help me
ap93
Feb 7, 2008
95
hey guys. is there any way for me to get videos that i make onto my iPhone. for example i made some montages using a capture card can i use handbrake or something to get them on my phone. Thanks
psylichon
Oct 31, 2007
16,591
751
40
Philly
Yes, you answered your own question. On a mac, Handbrake is the best tool for that. Are you having problems with it?
15,384
1,089
what kind of files are they?
you probably don't even need handbrake. iTunes can convert various video files into iphone-friendly formats.
ap93
Feb 7, 2008
95
hey. i can save videos to different formats. what type does it have to be for iTunes to convert it.
15,384
1,089
pretty much anything, i think. .mp4 or .m4v is what you need to convert it to, so if you can make it one of those right off the bat, you won't have to convert.
If you can't make them .mp4/m4v initially, then just drag the video into your library (or add the file from "File"), then right-click on the video and click "convert selection for ipod/iPhone". And that should do it.
