Can you change the "voicemail received" sound?
guest4
Mar 27, 2008
182
I would like to change mine. Anybody know how?
Thanks :laugh2:
guest4
Mar 27, 2008
182
Sure am. I didn't see anything in Customize 2.0 so I was wondering if i have to go through like WinSCP or something.
H
Hayesimus
Guest
i use ibrickr
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
Thanks :laugh2:
OK, using some program like WinSCP, navigate to:
System/Library/Audio/UISounds/
You will see a .caf file in there called Voicemail.caf. You need to replace this .caf file with your own .caf file. In order for you to get your .mp3 to a .caf file, you will need to do a little conversion, which ironically, I just got finished doing after reading a post in my thread on changing your text message sounds. Here's the quote:
Renaming alone will not do it with an MP3. conversion is necessary.
CAF is a renamed AIFF file (*.aif). AIFF is an uncompressed file (like a .WAV file).
iTunes can convert any file imported into an AIFF if you go into preferences/advanced/importing and select the AIFF encoder. Then just rename the file to the proper *.caf file you want to replace and SSH it to the phone.
Hope this helps!
psylichon
Oct 31, 2007
16,591
751
41
Philly
Hey, if no one else is around to do it...
KabaModern
Mar 31, 2008
4,549
32
Well, I was just going to put a laughing emoticon, but apparently my message has to be at least 10 characters... wtf?
So here: :laugh2:
Stupid iCafe...just kidding!
psylichon
Oct 31, 2007
16,591
751
41
Philly
just put 10+ spaces then a period. It looks like this:
15,385
1,089
or if you're really determined, you can type a bunch of crap like this and just make it all white.
guest4
Mar 27, 2008
182
WOOT! Thanks a lot! =D
