Can you JB 2.0.2 to 2.1?
radack1155
Jul 11, 2008
302
Austin, TX
don't feel like redoing all my stuff. And about the AptBackup app...
Is it easy to use?
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
Is it easy to use?
Your question makes no sense. You will have to upgrade to 2.1, then re-jailbreak. Never used AptBackup, but others in the forum have had success copying files off the iPhone via SSH, restoring, and copying the files back.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Is it easy to use?
AptBackup is simple to use. Just install it. Open it up and click Backup. When you sync your phone. The list will be saved. After you jailbreak 2.1, install Aptbackup, open it up and click on restore. It will bring up a message saying it's restoring all the packages you've downloaded from Cydia. the phone reboots and you're good to go.
I've used it a few times now and have yet to come across a problem.
*Note (Customize is broken in 2.1. So any file sets you downloaded will not work until it's updated.)
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Thanks, Cliffeman. Now the OP has the info he/she needs!
No problem. The thing that shocked me was, all the themes (battey, keyboard, etc) I downloaded for Winterboard were all in and already selected. So after the phone rebooted, everything looked like it did before. :D
