Can you receive a call while browsing web via edge?
I
iphonesinc
Guest
I'm curious. If I am browsing the web using Safari, can I make or receive a call on my iPhone?
Iwantmymtv35
Jul 2, 2007
134
I believe you would be able to. I mean, you can get one when you are listening to the iPod.
SmartAlx
Jun 7, 2007
1,087
I read somewhere that you can't since you can only have one connection to AT&T open at a time.
ps2gamer02
Jun 27, 2007
no u def cant i was on the internet an my girlfriend tried callin an i never got a beep or messege or missed called
jyong11363
Was reading the iPhone manual on Apple and the answer is no. According to the manual if you are using EDGE, ie in the middle of a data stream over the cellular network, and a call comes in it will go straight to voicemail. However if you are on WiFi it will ring through. Apparantly, the iPhone has only one receiver which can be used either for EDGE or a telephone call separately but not at the same time.
datafirm
Jul 3, 2007
That is no good, my Blackberry Pearl can do this. :(
theraker007
Jun 15, 2007
322
what if I'm reading a webpahe on edge but nothing os currently loading?
Page916
Jun 30, 2007
29
Don't know why it doesn't work. When blackberrys show GSM it's phone only, GPRS/EDGE is data and voice. So why doesn't the phone work when surfing the web on EDGE since the phone is
GSM 850 / GSM 900 / GSM 1800 / GSM 1900
cbh
Jul 8, 2007
It'll ring through
Then it'll ring through and you'll see a call notification on-screen.
