Can you sync a WM phone and iPhone devices at the same time
Kaaeed
May 24, 2008
UK
Hello
I am considering buying an iPhone, it will have to be atleast unlocked as I am not on O2. I will also need to put on 3rd party applications as the PIM functionality on the iPhone is insufficient for my needs.
I am considering whether to run 2 devices at the same time a WM device and an iPhone.
I am reading on here that there are problems synching the iPhone to a PC (XP) and outlook 2003.
Has anyone done this?
Thanks in advance
Kaaeed
psylichon
Oct 31, 2007
16,591
751
41
Philly
Before I talked my wife into an iPhone, she was sticking with her Cingular 3125 for several months while I marched happily into Apple land. The iPhone syncs fine with Outlook, and then to her phone... and vice versa. The only issue we came across was that appointments I entered on the iPhone would show up with "free" status on her WM once synced. Minor annoyance, but other than that we were pleased.
I suspect you'll be fine.
