Cannot connect to edge network - Canada: Rogers Wireless
harleyboy
Sep 15, 2007
I applied that latest hack by iPhonesimfree. Popped my Roger Wireless SIM card from my blackberry in and it all seemed to work perfectly. However, the moment I left my house I lost my wifi....so I started to test the Rogers network. The phone work perfectly but when I try to surf the web or get email it gives two errors:
Cannot connect to the EDGE network and then it says...you are not subscribed to the edge network.
I called Rogers Wireless and told them exactly what I was doing and they said that they blackberry uses edge and they would not block any device from the network. The SIM should technically work in any device including the iPhone.
Any ideas?
Mark
petalmom
Jun 30, 2007
494
You hacked your phone, it doesn't work, and you're surprised by this? Maybe you should be asking the developers of the hacking method that you used.
harleyboy
Sep 15, 2007
everyone is a smart ass....first ATT doesn't work in Canada smart guy. If the iPhone was usable in our country I wouldn't be hacking it. I got the thing for free at a conference and my blackberry died. So...why not use it.
Anyway, I got it to work. There are edge settings that have to be changed to Rogers and then it works.
The guys that sell the iPhonesimfree miss numerous points in their instructions. For anyone else that does it just be aware of this.
lolyq
Sep 16, 2007
harleyboy, excellent!. What did you exactly do? I have the same problem.
harleyboy
Sep 15, 2007
If you go into your Network settings there are Edge settings. When you get the phone they are set to cingular network. You have to change the settings for Rogers or Fido in Canada:
Rogers
APN: internet.com
Primary gateway IP: 172.25.0.107
Username: wapuser1
Password: wap
Fido
APN: wap.fido.ca
Username: fido
Password: fido
Primary gateway IP: 205.151.11.11
Port: 8080
There is no field for the IP address so I just ignored that. Once I put this in it started to work.
Now if I can only get my phone to last more than 6 hours per charge we are moving forward.
khojaman11
Oct 3, 2007
11
Primary Gateway
Where do u put in the primary gatway
Rogers
APN: internet.com
Username: wapuser1
Password: wap
Fido
APN: wap.fido.ca
Username: fido
Password: fido
Port: 8080
