Cannot connect to iTunes Store
Aug 23, 2007
Anyone else getting this error message when using the new iTunes button that was available after the upgrade? My WiFi is definitely on ...the buttons at the bottom (featured, top tens, search, downloads) do highlight when i tap them but nothing appears on the screen ..just the error message "Cannot connet to iTunes store".
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
I am having the same problem. I've also seen mention on Apple Discussion Forums.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Here's a fix that worked for me from the Apple Discussion forums.
  • Select Settings
  • Select General
  • Reset
  • Reset Network Settings
  • Allow Reboot
  • Select WiFi
  • Select your network
  • Try iTunes WiFi Store
Good luck!
-Chris
kurrupt_1
Apr 21, 2008
  • Select Settings
  • Select General
  • Reset
  • Allow Reboot
  • Select WiFi
Good luck!
-Chris
I did the reset but now I can't log to my wifi network. The screen comes up but it wont let me type in the password.
Any thoughts?
Oct 24, 2008
  • Select Settings
  • Select General
  • Reset
  • Allow Reboot
  • Select WiFi
Good luck!
-Chris
This worked for me, but not at first. After I did this, I had to go into Settings, then General, then Network connections, and add my WiFi network at work (it's not discoverable), including the name, security type (WEP) and password. Then, it STILL didn't work. I got onto Safari and that immediately brought me into a wifi webpage that asked for an additional id and password, which I entered. THEN I went to the App Store and EVERYTHING worked. Now, my network at work is different than many of those you'd be using, but once I did the reset and put myself into a positiion such that my browser was fully capable of surfing, I was able to do everything. What changed between the "before reset" config and the "after reset" config? I have no idea, but now I can use iTunes no problem on my work wifi, and couldn't earlier.
Hope this helps somebody.
crashtc2
Oct 26, 2008
iTunes is NOT available on the 3g network
Not sure if this matters in your case, but it might.
iTunes is not available on the 3G network provided by AT&T. You have to connect to some other wifi network if you want it to work.
I have no idea why. It seems pretty stupid. But there it is.
iamse7en
Jul 27, 2007
140
This is not true
[redacted]
psylichon
Oct 31, 2007
16,591
751
40
Philly
Appstore is available off Wifi, iTunes store is not. They are different apps on the iPhone, of course.
seb481
Aug 3, 2007
774
San Diego
Found a fix for that problem.
1. SSH to /private/var/mobile/Library/Caches/com.apple.mobile.installation.plist
2. back up and delete the file
3. Reboot
Worked like a charm for me
newbv11
Nov 23, 2008
sebefore81 has the best solution.it works! Thanks a lot
denture59
Jan 28, 2009
Thanks for info Chris. Did reset and reboot and all working now. :laugh2:
simcafe
Feb 10, 2009
Hi, Im on a Jailbroken 2.2.1 T-Mobile UK, and got the feared "Cannot connect.." message, and could not connect to AppStore or iTunes over 3G or Edge.
Removing "com.apple.mobile.installation.plist" did not solve the problem - it just comes back after a reboot. I've tried rebooting it in several ways (Bossprefs, power off/on) to no avail.
Then I got tired of it and completely reinstalled the phone from scratch. After Pwning/Yellowsnowing, i did not recover the previous iPhone data in iTunes, so that's a proper clean install. Without doing anything else, I tried the app store first thing and it gave the same "Cannot connect.." :( Safari did work so connection was fine.
Then I entered my original o2 sim to which it was previously locked, and it did work..
But still not on T-mobile.
So, this problem is a little deeper than I hoped for, any ideas are very welcome.
Gmun
May 1, 2009
I know the FIX
Any thoughts?
Gents, I struggled with it myself. Here is the solution
-check for the date on your iPod touch
-Ensure it is the correct date, iPod touch resets to 2000.
-Change to current date and voila you will be connected to iTunes Store
:eek:
28,406
5,539
Did this - still does not work
You probably won't get a reply. His post is over a year old and it was the only one he ever made on this forum.
mcqt
Dec 4, 2009
How?
3. Reboot
sort of new to this...but how do you SSH into that?
wlt.
Dec 24, 2009
A Problem Updating Genius in iTunes
Hi, I'm new here and I'm hoping I am in the right forum . . .
I have an iPhone 3G and I'm running iTunes 9 on a Windows XP OS. The iPhone sync's okay, but when I go to "Store" and <click> Update Genius, iTunes gives me this response . . .
"We could not complete your iTunes Store request. An uknown error occurred (4002).
There was an error in the iTunes Store. Please try again later."
Since it's been a couple of month's "later," I figured I'd better seek help from those who know. Is it my Symantec NIS? I know the Windows Firewall is set to allow iTunes. I would like to "refresh" some playlists, but I get errors saying the Genius needs updating.
. . . A catch-22. Has anyone seen this? Thanks. - wlt.
L
linaelectronic
Guest
That happens when your connection speed is slow. Have you run a speed test?
wlt.
Dec 24, 2009
Am I In the Right Forum?
I am having problems on my Windows XP machine accessing the iTunes Genius.
I have iTunes 9.0 (re-installed once) which sync's with my iPhone just fine. However, if I want to create a Genius playlist, which iTunes does not recognize, e.g. Boz Scaggs, "Loan Me a Dime," iTunes says to "update Genius."
When I move to update Genius, I get the message "We could not complete your iTunes Store request. An unknown error occurred(4002)." Everything worked fine with iTunes 8.0, I mean Genius had no problems with ANY song or accessing the Store.
Sure, I can access the Store if I want to buy something; otherwise NO WAY.
If this is the wrong forum, please tell me where to go . . .
Thanks.
