Cannot see how many contacts listed
Zman-iPhone
Jul 26, 2007
ok, so at the bottom of the contacts, can you see how many are listed?
well i cant, not until i add one, then delete it.
do you think that if i restore it, it will be fixed?
and will restore keep everything, (contacts, calendar, ect.)
AND*** will it mess up the bettery life?
THANK YOU ALL
zmaniPhone
Silverado
Jul 6, 2007
332
Hmm... what do you know, I have the same problem. Seems like a bug.
I'd ignore the problem for a while. How often do you want to see that number?
Zman-iPhone
Jul 26, 2007
not often, but i'd like to know that its there.
so if its a bug, then its happening to everyone?
AND, do you think that a restore would fix this?
masond24
Jul 25, 2007
I just checked mine and it did the same thing. I added a contact, deleted and the # of contacts is back.
Zman-iPhone
Jul 26, 2007
we should restore, but i just want to know if it deletes contacts, Calendar events, and hurts battery life..
iPhobos
Jul 25, 2007
201
I just deleted and added a new contact as well in order to get the count at the bottom of the phone. I guess it might have something to do with syncing it to iTunes. Maybe after we sync it next it will stay or worse it will take the count away and we'll have run through the sequence again. Either way definitely something we should point out to Apple.
insocal
Jun 25, 2007
58
ok, i agree, maybe a restore will fix it, or not, who knows.
Is this a feature that only appears when you scroll all the way to the end of the CONTACTS? Or is it ALWAYS visible when you are in the CONTACTS APP no matter what LETTER you are viewing?
