cant access themes or reinstall themes on Cydia....pls help
dankduke
Sep 11, 2007
278
Austin, FL
photo.PNG so somehow i accidentally deleted the THEMES folder through idisk.
This is for my iPad2....How can i reinstall these packages and also WINTERBOARD....i was trying to re-install winterboard and the themes that i lost....but everytime i do that i get this message...how cna i manually fix this....
Thanks in advance if any1 can help it would be greatly appreciated...photo.PNG
Reboot and then reinstall WinterBoard in Cydia. The themes folder will be recreated.
dankduke
Sep 11, 2007
278
Austin, FL
How can I manually DELETE winterboard and then REINSTALL it...
I believe that is the step i Need to take...
i tried a reboot and install and this is what i got..
i cant uninstall WINTERBOARD.
I cant reinstall...it sux...
Use iDisk (or SSH, iFile, DiskAid or iPhoneBrowser) to delete the WinterBoard.dylib file. Back it up in another location first. It's located here: /Library/MobileSubstrate/DynamicLibraries/WinterBoard.dylib. Then reboot and see if it will allow you to uninstall or reinstall WinterBoard.
  • Like
Reactions: dankduke
