Can't add videos?
bizzy045
Jun 27, 2007
93
i dunno what happened. every time i try to add a video nothing happens. i don't get it. it used to work fine. even drag and drop into iTunes wont work. i saw people having this problem a few days ago, but i can't find the thread. i did a search. can anyone help?
jptolife
Jul 15, 2007
645
New York City
You have to sync the videos, can't just drag them to the iPhone. Go to the videos tab in the iPhone and select the ones you want to have. That should do it.
bizzy045
Jun 27, 2007
93
they are..i added them before..i just realized that music wont add either...so when i try to add a file in iTunes, nothing happens...this is really really weird.
alb0zf1n3st
Jul 2, 2007
624
So none of these files are even in your library when you import? try to reboot your system i know iTunes got bugs
bizzy045
Jun 27, 2007
93
i tried to reboot...and repair..i was even willing to re-install iTunes, but when i tried to back up my entire library, it keeps telling me to insert blank disc..i tried 10 blank discs...none worked...i cant even end the process iTuneshelper.exe. i think thats what the problem is. i get an error saying access is denied. if i can somehow end that process and reboot, it will work im sure. any ideas? thanks.
princess_80854
657
Hold the POWER button down on your computer until it completely turns off. Then press Power again to restart.
