Can't change Weather Location
KTORRES1120
Dec 28, 2007
53
My weather location is stuck on Cupertino and New York. Is there any way to change this?
RTWilliams2
Oct 3, 2007
66
Open up the weather app and in the bottom right corner there is an i. Press the i and the page will flip allowing you edit the locations.
KTORRES1120
Dec 28, 2007
53
Oh my god i feel like an Idiot, that was soo easy. Thanks RT!
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Also, while you have in the "i" flipped and you have say 8 or so, you can click edit and move them into a specific order.
lsilver
Aug 20, 2008
I was wondering the same thing. Thanks for the help! Thanks LS
brick
Aug 21, 2009
Still doesn't work
I can mine (iPod Touch) to get it to a screen where it lets me enter my location info, but it does not recognize my location (zip code or town name). I have no problem using doing that info on Yahoo Weather website on a PC.
Help?
Do I need a s/w upgrade?
SLalario
Feb 26, 2010
Bothell WA
This help me also- thank you! However, on the main screen the weather icon still shows a sun and 73. If I tap the weather icon, my area reflects correctly! Is there not a way to have the weather icon reflect my area on the main page?
Jul 8, 2009
92
You can get this info on your icon by downloading Weathericon from cydia.
Jan 31, 2012
Also on the iPhone 4 once you tap the I on the first page turn local weather off to add more locations
Deb H
Sep 25, 2013
Open up the weather app and in the bottom right corner there is an I. Press the I and the page will flip allowing you edit the locations.[
I just purchased an iPhone 5c. There is no I at the bottom. Does anyone know how to change to other cities? I have tried putting in my town, and even Chicago, and it says there are no results found.
28,437
5,560
Press the three small lines in the bottom right corner. Then press the + sign. Then type "Chi" and wait a second. Chicago, Illinois will be the first choice.
Deb H
Sep 25, 2013
Thanks!
