Can't connect to 4G
XrayeyeS
Sep 14, 2012
I've been on the phone with AT&T and they think I have a bad SIM card. What are you thoughts? I can text and be on wifi fine. Here is the message I receive
thanks
XrayeyeS
Sep 14, 2012
i had this problem, i just took it out blew out some dust and other crap, then worked fine. If that does not work then i predict AT&T is correct
Thanks for the reply. I just tried it, but no success. I'll head into AT&T in the morning.
