Can't exit 'wiggle mode'
Thomas_2303
Jan 5, 2012
17
Hi,
When I go into wiggle mode and I want to exit by press and holding the home button, it doensn't work. My apps keep on wiggling. Also, when I'm on my second page f.i. on my springboard and I tap the home button to go to the first screen, or when I'm in a folder and I tap the home button to close the folder, it doesn't work. Exiting an app does work and opening the multitasking bar works as well.
I already tried recalibrating my home button, but no luck.
Any suggestions would be much appreciated.
Thanks in advance.
Thomas
Try a hard reset. Press home and power until you see the Apple logo.
