Can't find my ringtones
Nov 8, 2014
50
So, I had downloaded a couple new ringtones before 8.1.1 came out, and after I installed the new software I cannot find them.
I even downloaded again and they are not where they should be. I also am finding that my ringtone is randomly changing after the update.
Any ideas on where those ringtones might be?
28,365
5,506
Is your phone synced with iTunes on your computer? They are listed under under Tones. Check the boxes and sync.
Reboot and then set a new ringtone under Settings > Sounds > Ringtone. Post back if it does it again.
