can't get tightVNC and VNsea to work
Aug 31, 2007
i downloaded VNsea via app.instl and tightVNC for windows via internet, now what? Also setup account for navizon but tells me i have an invalid username and pasword. any ideas?
Boatski
Sep 7, 2007
81
Login info is case sensitive
6,682
49
AS far as the VNC portion of your question, you need to create a connection in VNSea to the IP address that you want to connect to. The PC you are trying to remote into needs to have either Tight VNC or Ultra VNC running on it.
If you have a firewall or even a router, you will need to enable ports 5800 and 5900.
Because I use a router, I had to "clone" my cable modems IP address to my PC. This allows direct access more or less because I know no other way of setting it up.
