Cant install GARF(SIMon) on iPhone ..HELP!
barrycompston
Nov 29, 2007
Hi
I have a folder called GARF (Simon) with some files in it.
I have no idea how to install it to my phone.
Any guide would be great.
Baz
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Hi
If I cant use the installer, is there a guide on how I could install this program. ?
Here is what it says:
According to the developer, the game is in it's very early stage but fully functional. Unfortunately, it's not available on Installer yet so manual install of the game via sftp is required.
Also at top it says:
proceed at your own risk.
That would scare me. Then you come back and HELP!
Tinman
4,334
183
Aridzona
This game works fine and can be installed via installer if you add the following source:
modmyifone.com/installer.xml
Mike
barrycompston
Nov 29, 2007
you're downloading the skin i designed. it just replaces the graphics with the stock garf skin. you upload the graphics files into the Applications/Garf.app folder overwriting the original ones.
hi
don't mean to sound stupid.
could you give me a easy guide to install this application.
thanks
baz
meiphones_brill
Nov 16, 2007
797
hi
thanks
baz
Tinman suggested an easy way. Go to Installer and add
as a source - this should bring the Garf application into the list of packages that you see when you touch 'install' down at the bottom.
select it - and choose 'install' - the button in the top RHC
Hope this helps
barrycompston
Nov 29, 2007
Hope this helps
Hi
I have installer on my phone, how do I add modmyiPhone.com/installer.xml to it and where then do i put the folder with garf in it ?
thanks
