Can't Jailbreak, Help please!
Hinezy
May 24, 2008
533
Mt.Carmel, PA
I have an iPhone 3G and a mac and haven't been able to jailbreak using quickpwn. I checked all of my firmwares and settings and everything is correct. Right after the part where you release the home button and your screen goes black with the Apple logo in the center my screen goes white instead. quickpwn continues on my mac as if nothing is wrong until it's finished but my phone stays white until I shut it off and restart it. The only thing I noticed different from when I do it compared to the youtube video is when it asks for my name and password my symantic antivirus scans quickpwn cydia and installer. I tried allowing it to scan it fully and I tried canceling it right away neither worked. I'm not sure if this is causing the problem or not and I don't know how to disable the antivirus so it don't kick on.
Any help would be greatly appreciated.
Is your Mac running OS X 10.5.6? Sounds like it. If so, there's your issue.
Hinezy
May 24, 2008
533
Mt.Carmel, PA
Anyone have any tips? I'm still having no luck after trying everything I can think of. I still can't figure out how to stop symantec from running. Anyone know how to disable it?
