Can't make or receive calls
Bhay99
Jun 30, 2007
21
I have a full 5 bars, can go on the internet and text but I cannot make or receive a call. When I try to call out it just beeps and says "call failed" and I can't get to my voicemail either. I've had the phone since it came out and have had no problems like this before.
Anyone know what I can do? I've powered off twice and tried to go outside for better reception and nothing is working.
Thanks.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I would suggest trying a restore. If that doesn't work, try taking the SIM card out and then putting it back in. Are you jailbroken/unlocked?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Thanks.
Nobody goes outside anymore.
So if you have had the phone since june then you may be housebroken or UnClacked?
What firmware are you on?
And if you are on other things then let me know.:p
Bhay99
Jun 30, 2007
21
i haven't modded or used jailbreak at all...my phone is untouched in that regard
KNK
Jul 22, 2007
2,391
Stevenson Ranch
So what is the firmware?
I would suggest you have the download the latest version of iTunes, reboot the computer, then op it, dock the iPhone and do a restore.
If it does still not work then take it in to the Apple Hospital and let the doctors take a look at the patient.:)
Bhay99
Jun 30, 2007
21
removed the SIM card and did a restore and still the same problem...what the hell, this is annoying
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Wait, you said you were not jailbroken.
Now you say you removed your sim card to restore?
Are you unLocked orig?
If not put the sim card back in and do a restore.......
Bhay99
Jun 30, 2007
21
nah i put the SIM card back in before i restored...just took it out and put it back in as suggested above
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Try calling 611 and see if it goes through. And also (I've done this, but do it at your own risk) dial 911, let it force a signal and hang up before it starts to ring. Once the phone connects to the network, you should be good again.
Also, trying turning airplane mode on/off over and over again for a bit and see if that works.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
If you tried a restore with doing the sim thing (which I do not recommend) and it still does not work then I would take it into Apple for them to look at it.
Make sure you are not jailbroken or unlocked before you do.
Also ask for a brand new phone, not one in a white box, those are re-furbished.
Bhay99
Jun 30, 2007
21
Thanks for the new ideas
I tried 611 and it didn't work and also toggled airplane mode on and off, but still nothing...only think I can think of is that the whole network is down in my area or that my phone is just f'ed up for some reason
Bhay99
Jun 30, 2007
21
well i'm defeated....don't know how a phone can just stop working like this, seems stupid
I don't have any Apple stores in my area....can i go to an AT&T store instead?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
yes, but that sucks, dealing w/ ATT. If you can, call Apple and see if they'll do a handset exchange via mail for you.
themanofthedark
Jan 5, 2008
2,674
25
Boston
<starts chanting>
AT&T sucks!
AT&T sucks!
AT&T sucks!
t-mo-bile!
t-mo-bile!
t-mo-bile!
</chanting>
evangary
Jan 8, 2013
9
Have you attempted a DFU restore to original firmware? If anything went wrong during your jailbreak process a DFU restore to original firmware will likely solve this problem. When, or if you decide to attempt a jailbreak again I would suggest you re-create the custom firmware as that may be the source of your issue. If you are using windows have you double checked permissions and compatibility options? If not you may try Redsn0w again before a second attempt at custom firmware.
enjoylife1788
Jan 7, 2011
186
What about a damaged card? It's been reported many times. Get a new SIM card. Or try some other SIM card and see if it works.
Sent using iCafe app
28,365
5,507
You replied to a thread that hasn't been posted in for five years.
