Can't send outgoing emails.
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
Some reason when I try and send outgoing emails is says "Cannot send email" Send address was invalid. I even tried sending myself an email and no luck. I can receive emails perfectly fine though.
Any Suggestions ?
Jan 16, 2009
3,230
59
Mississippi
Make sure your email account is set up correctly under settings-mail, contacts, calendars. You may have to delete and reinstall the account. Some POP accounts don't send good unless by WIFI so I use my Yahoo account with no issues.
psylichon
Oct 31, 2007
16,591
751
41
Philly
What email service are you using? If it was a manual entry, are you sure you input the outgoing server address correctly?
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
I am using a comcast mail server. I did not input any information myself when I first came home with the phone and synced it automatically synced the email account from my windows mail account.
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
Ok I reseted the account and everything works fine now. One small problem though it keeps saying I have 3 unsent messages how do I delete those and make them go away.
Also for some reason none of my apps work now either. I click on the app and it returns the home screen. WTF!@!
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
Ok did the update for some of the apps and now they all work again. I am still trying to figure how to delete my outbox ? Can anyone assist in this one ?
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
Ok .... to the first person who can help me delete my outbox I will reward them with a 5.00 off coupon for ZAGG.com I will PM the code. Every time I open my mail it says I have 3 unsent messages. How do I delete these ? That is my question.
Bitewound
Sep 7, 2007
1,297
134
Biteyland NYC
Click on the mail button and then the account name and they should be in drafts or sent -just edit and delete
RS1001
Aug 14, 2007
56
Minneapolis
Delete your mail account on your phone and then create it again, That should take care of it
iphonewarrior
13,847
702
Delete your account and then set it up again.
You may have to login to your account online so that you can delete any messages may need to be sent on there.
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
I am trying to delete and re create the account once again to delete outgoing "sent" emails and for some reason it is not working this time. Does anyone have any tips or suggestions ?
