Can't swap dock images!
Pharaoh
Sep 7, 2007
91
I use my dock swap ap, pick a new dock image, and go back to home screen, refresh, and it doesn't change it. I try to uninstall my dock swap but says there is an error 'error during uninstall scrip execution!'
420greg
Jun 26, 2007
845
Orlando, Florida
This is happening to everybody that upgraded there summerboard yesterday.
I am sure there will be a dockswap update to correct it very soon.
There was a dockswap update yesterday that I thought was the fix, but all it did was make me uninstall the image dockswap image pack.
Sep 12, 2007
11
Forest Park, IL
There was another dock swap update earlier, with a new transparent pack, but it still didn't fix the issue.
I just took the dock image I wanted and replaced the one in summerboard via mobile finder. Works fine if you're not gonna be swapping dock images all the time.
akophone
Aug 1, 2007
300
Or SSH could be your answer:
Go to var/root/Library/Dockswap and copy the .png that you wanted back.
Go to var/root/Library/Summerboard/Default/
Delete "Dock.png"
Restart your phone.
Done!
