Can't sync my music
Jun 20, 2007
somewhere
i never owned a ipod so this is new to me but how to i sync my music and tv shows,im able to sync my photos and thats it.thanks
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You have to make sure all your music is loaded into iTunes. It should be automatic.
Jun 30, 2007
22
LOL, you need to put check marks on the box for each tab, i.e. music, movies, photos, etc., before you click sync. If none of the boxes on "music" is checked, of course it will not sync. Also, make sure you don't have an ungodly amount of music on your iTunes or it will create a separate iPhone favorites which may not include your faves.
Jun 20, 2007
somewhere
i have one song in iTunes and for some reason it skips music and just syncs photo.cant get it right.
AU girl
Jun 23, 2007
OK I have tried since 7 last night getting my iTunes on my iPhone ( uninstalling iTunes restalling etc.even upgrading my AOL page) OK. Go to your iTunes page. Click on music under the heading Library. Put a check mark in the boxes of the songs you want on your iPhone. Then on your iPhone information page for Music put a check mark on Sync music and sync all songs and playlist. (hint it only does the songs you checked earlier) Then click sync on the bottom. IT WORKED FOR ME! GOOD LUCK!
