Can't sync notes with 3.0 . . .
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I can't sync notes on my 3G 3.0. I see the Notes box, and check it, but when I hit the sync button iTunes unchecks the box? :eek:
Any suggestions . . .
6,682
49
What are you trying to sync Notes to? I think the option is for Outlook, but don't quote me on that. If you aren't syncing your contact and calendars to a program that has "Notes" in it, then I think iTunes automatically removes that option. Notes will get backed up like they always have, but you won't have access to them like you would if you had Outlook or other program with a Notes section.
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I'm on a Mac. I don't use Outlook. I just started using Notes on my phone. I sync Calendars, but as I said, as soon as I hit Sync, iTunes unchecks the box? I guess I could email the Notes to myself. I don't understand the Sync notes in the Notes sections of iTunes, I guess.
But thanks . ..
6,682
49
What I was saying is that you have to have a program you can read the notes with on your MAC in order for you to have the option to sync, otherwise, what is it syncing to? If iTunes does not see a program to sync to, then it will automatically remove the option, which is why the box keeps getting unchecked.
Marianne
2,326
29
Massachusetts
marianneschultz.com
It looks like this is a common issue at the moment according to Apple's support forums here. I didn't read through the whole thread, but there are some suggestions to try to get it to work on the first page...
Marianne
2,326
29
Massachusetts
marianneschultz.com
They're synced to Notes in the Mail application that comes with all Macs. I personally think this is a little odd since Notes and Mail don't go together for me automatically, but there's nothing that needs to be selected for this to take place – this is nice, but it also means that Mac users don't have any other choice in where/how to sync Notes without 3rd-party software... :(
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
Where do I find the Notes that reside in the Mail application? I see an option for a New Note, but it simply adds a note to my in box. What am I missing?
Marianne
2,326
29
Massachusetts
marianneschultz.com
I have chosen to keep my Notes out of my inbox as I like to keep them separate. In Mail, go to Preferences/Accounts/Mailbox Behaviors and uncheck Store notes in Inbox for each account if you'd like to do the same.
They appear in the sidebar under the Reminders section, along with To Do's.
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I found the Mailbox Behaviors all right, but I can't find the Reminders, and To Do's in the sidebar?
6,682
49
Make a note and see what happens. It might be you have nothing to store, so nothing shows up
