Can't sync with Outlook 2000
princess_80854
657
Everything that I have read says that the iPhone won't sync with Outlook 2000. You can at least sync over your contacts through the Windows Address Book if you're using XP.
Bleaker409
Feb 24, 2009
I couldn't figure out how to export my Outlook 2000 contacts to the Windows Address book, but I found a pretty quick and easy way to sync my contacts anyway.
First, I exported my Outlook contacts to a .csv (comma separated values) file. I then set up a gmail account and imported my contacts into that. Finally, I set iTunes to sync contacts with Google Contacts.
Works beautifully, if somewhat inelegantly. Not wanting to leave all those contacts online, I deleted them and turned off contact syncing. The whole process took maybe 10 minutes (including creating the gmail account) so it's not much of a hassle to update contacts when needed.
