Can't text pictures
superchaos
Feb 20, 2013
84
Any reason why I can't send pics through text?I think I'm suppose to be able too.
Sent using iCafe app
Dec 15, 2008
5,386
340
27
Pensacola, FL
What happens when you try to send pictures through text? You should be able to text pictures, yes. Some larger photos do take longer to send, however.
superchaos
Feb 20, 2013
84
It loads almost all then stops then says not delivered with an explanation point.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Sometimes even when it says not delivered, it actually still delivered the message. I've noticed this when sending regular messages.
What operating software are you currently on? Have you tried a full restore through iTunes?
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
Also, make sure you have Cellular Data set to on. (Settings > General > Cellular)
superchaos
Feb 20, 2013
84
Had to do a restore once and had problems with that at the time.Im using an iPhone 4. I'm using wifi with cellular data off.Would that matter?
jmp316
Jul 10, 2008
1,048
141
Even if you are on wifi you will still need a cell signal to send texts, unless its an iMessage. The fact that you have cellular data off explains the problem. Do you have a data plan with your phone?
superchaos
Feb 20, 2013
84
It worked with cell data on.Thanks. I should be able to get text with it off I think because I have.I always use wifi and keep that off because I have the least data plan.
jmp316
Jul 10, 2008
1,048
141
iMessages (Apple to Apple product) is all data and you can send them on wifi alone. They show up in Messages.app as blue. Regular SMS messages require a cell signal and they up green in Messages.app.
Maybe you're confusing the two.
superchaos
Feb 20, 2013
84
Probably.Haven't done much texting with this phone.i just remember getting a text from someone then I sent back a response and a pic but the pic wouldn't send but I thought I remember the actual text went through a separate text telling that I couldn't send a pic and was going to send through face book.
