Can't update my iPhone
Mikeg13021
Feb 7, 2011
4.2.1 I am using wifi but it happens every time it will all load but when it goes to put it on my phone it says it times out
Mikeg13021
Feb 7, 2011
It says there was a problem downloading the soft ware for your iPhone and network connection timed out
RoofMonkey
Jun 21, 2010
8,921
1,983
Try looking at this thread, find the appropriate firmware / IOS and download it on your computer. When you plug into iTunes, you should be able to do a shift & right click on the device to select the file you downloaded. Maybe this will work for ya.
http://forums.everythingicafe.com/threads/ios-official-download-links.76516/
Sent from my iPad using iCafe App
Scott AKA RoofMonkey
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
This is why I usually find the newest version of iOS for my particular iPhone and download it first. Then I hold the SHIFT key when I click Updateand it allows me to navigate to wherever I chose to save that download and use it to update my iOS software.
