Carrier Logo iPhone
djdoubler
Dec 16, 2007
is there anyway to change the carrier logo on the iPhone using firmware 1.0.2? this is what it came with when i bought it unlocked. any one help me out please?
Customize?
- John
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
use ibrickr to upload a carrier logo of your choice onto the phone. You'll have to search for exact directions.... Not hard and quite a basic modification.... Good luck
djdoubler
Dec 16, 2007
customise does not work i have tried that also have tried "make it mine" that does nothing either. im using O2 when i use iPhoneinterface.exe i can not find anything on the phone using the tutorial on YouTube etc...
djdoubler
Dec 16, 2007
everytime i try and type something in it comes up with....
:no such file or directory
r_command
djdoubler
Dec 16, 2007
can you change the carrier logo if you are on O2 or just AT&T?
termleech
Sep 7, 2007
1,154
McPherson, KS
I think the reason it's having an issue is the carrier logo might be called something different on the O2 phones. Log in to the phone and go to
/System/Library/CoreServices/SpringBoard.app. On AT&T phones there is a logo called FSO_CARRIER_ATT.png which is the logo you see when you are on the home screen. There is also a logo called Default_CARRIER_ATT.png where you see everywhere else. The ATT might be replaced with O2 in your case which is why none of the tools are working correctly. I'd give it a try manually and see what happens.
