Carrier Update dropped from 5.0 to 3.5
cdelauz
Jul 13, 2008
291
Did anybody noticed that in the beta 3 that the carrier changed from 5.0 how I had on beta 2 to 3.5 on beta 3.
shutter13
Jan 8, 2009
2,208
153
If you restored, then yes, it would overwrite your custom ipcc file. 3.5 is what beta 1 and beta 2 shipped with. You can shift + update the custom file again, if you need to to activate tethering, but the cellular data option does not work anymore.
cdelauz
Jul 13, 2008
291
How come it doesn't work any more? So its not working for no one no more?
shutter13
Jan 8, 2009
2,208
153
Didn't work for me. I shift + updated and my carrier settings were still 5.0 and the field for cellular network data was still there, but if you selected it, it would crash to the spring board. I re updated the carrier file to the 5.0 version...same thing. I just restored beta 3 (restored from back up) and my carrier settings are 3.5, the cellular network data field is gone, but the tethering field is still there.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Apple unlocked tethering for everyone in beta 3, you don't need a special ipcc file to get it working anymore. MMS is also apparently working for almost everyone now too, including me.
faseone
Oct 2, 2007
203
I'm on Beta 3 but don't see the tethering option... where can I find it?
shutter13
Jan 8, 2009
2,208
153
Settings>General>Network towards the bottom.
faseone
Oct 2, 2007
203
hmmmm... that's interesting, I don't have it.
VIPERxGTx2000
Jul 7, 2007
112
I can't find a tethering option under any settings and i'm on beta 3
diverdown
Sep 12, 2007
970
49
NYC
I have the internet tethering option on my beta 3. Its found in "Settings General Network" right under Data Roaming.
~S
faseone
Oct 2, 2007
203
maybe my beta 3 is not beta 3?
faseone
Oct 2, 2007
203
yes I have that one, but is it possible its just a modified beta 2... Im gonna try a restore and see if it updates...
faseone
Oct 2, 2007
203
Nope, I guess I'll try updating my carrier settings...
Ok that worked... update carrier settings, I can post the file I used if it's allowed.
shutter13
Jan 8, 2009
2,208
153
Yeah if you were on beta 2 and had not used a file to actvate the tethering option and you updated rather than restored... The update will not overwrite your ipcc settings. Restoring does.
faseone
Oct 2, 2007
203
So then its not automatically included in beta 3.. its just those that "updated" from beta 2 who had it then have it in beta 3?
shutter13
Jan 8, 2009
2,208
153
Not if you update, but it is if you restore. Restoring wipes the phone, puts the new os on and then you can restore from a back up to get your settings and user data back.
faseone
Oct 2, 2007
203
My problem is that I have restored numerous times, carrier settings are 3.5, but no tethering option. The only way I get that option is if update to the 5.0 carrier settings.
If its enabled in beta 3, why don't I have the option with a restore?
shutter13
Jan 8, 2009
2,208
153
Honestly, I don't know, I am assuming you are on AT&T and are in the United States. Where did you get the file you used to upgrade?
termleech
Sep 7, 2007
1,154
McPherson, KS
You still have to apply the carrier update to get the tethering to show up. I'm on stock Beta 3 and it's no where to be found. What they were saying is if you setup the phone as new then the carrier settings will revert back to 3.5. If you set up the iPhone from a backup (a beta 2 backup) that had the carrier settings applied they will stay applied and you won't have to reapply the 5.0.
