categories on iPhone
dunky13
Nov 17, 2008
Hi i have an iPhone 3g 3.0 Jailbroken and cydia keeps crashing but i've got icy and i installed categories so that i got some folders, today i made a folder called: Cydia & Icy Apps but it doesn't show up on my springboard, in there was
Dtunes
Categories
iFile,
iHetube
and some more
but the folder is not showing anything
so do i have to restore?
Greets
Dunky13
5,578
That app is more trouble than it's worth IMO.
Try this, it's supposed to uncategorize them.
HERES A FIX!: I did the same thing. After a lot of searching, I found if you turn on parental settings, go to home screen, go back and turn off parental settings, and then go back to home screen your apps will appear. You may need to restart after this process too. This has worked for me multiple times.
