Certain apps not appearing on iPhone
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
When I install certain apps, like iSpazio Themebuilder, or themes like 3dee summerboard theme, they seem to install ok, but then I can't find them anywhere on the iPhone. I can't even find them when I SSH to the phone. And one of them--3D bold black dialer--won't uninstall, even though it wasn't there in the first place. I get that 'Main script execution failed' message. Any ideas?
psylichon
Oct 31, 2007
16,591
751
40
Philly
My only guess:
They're installing to root instead of mobile. I know this is often an issue with summerboard themes. Once they're moved from root/library/summerboard to mobile/library/summerboard, they will show up in SMBprefs. I don't know why some themes are installed to root.
Apps, I dunno. Could be the same thing, probably not.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
My only guess:
I looked---nothing there.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I reinstalled the 3dee theme and it did appear in the root/library/summerboard directory. I moved it over to the proper one and voila!
x999x
Aug 6, 2007
1,656
Delete /var/root/Library/SummerBoard in WinSCP, then open up the little Terminal window under the "Command" pulldown menu.
Type in:
ln -s /var/mobile/Library/SummerBoard /var/root/Library/SummerBoard
Press enter, and you'll have a symlink there now that will point to the correct folder. Outdated themes will install to the correct directory, and uninstall properly.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Type in:
I'll try it out a little later, thanks!
darklight
Mar 23, 2008
123
Boston.
honda i beg you, change your myspace ID to just hondamaker.
it automatically changes the link to myspace.com/[yourid], and it doesn't stretch out the forum like a mother on the iPhone.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Type in:
didn't work, believe it or not. I'm pretty sure I did it right. I'll try it again.
psylichon
Oct 31, 2007
16,591
751
40
Philly
word .
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Type in:
Tried it again, made sure I had everything correct, still didn't work!
darklight
Mar 23, 2008
123
Boston.
just until I had my reveal done - I'm trying to make one for 2,000.
