Change Dialing Format - How to (Firmware v1.1.1)
Stevonw
Sep 14, 2007
560
UK
The international menu is also available (this is the easiest way to achieve UK dialing on a v1.1.1 US iPhone) and also allows you access to the International Keyboards.
All you need is v1.1.1 Jailbroken phone with Installer
1) Add the source "http://i.unlock.no"
2) Let it Refresh the Sources
3) Now choose the unlocking tools folder (under the install tab at the bottom)
4) Choose the "Enable International Menu" file and install it
5) After this file has installed, you can instantly access the menu by going back to the springboard and choosing settings, general, international and set your preferences
Hopefully that provides a quick fix to all you v1.1.1 international users :D
Hopefully this clears up some issues FOR PEOPLE OUTSIDE THE USA .
bfakhroo
Oct 2, 2007
132
is there an easy way to remove all dashes and brackets? for e.x 12345678
Stevonw
Sep 14, 2007
560
UK
When you choose the country UK in the International dialing menu it has no dashes at all ;)
You could manually edit the file via SSH to customize it to whatever you want though.
