Change file extension from mp3 to M4R, but ringtones don't load?
I
iphone
Guest
Got a question. İ got like hudreds of music stored in pc. İ have changed the format from mp3 to M4R. After changing the songs, the logo's turned to something like 'RİNG'. İ open ringtones from the İtunes, selecting the music files that İ have changed. Nothing happens. Does'nt it suppose to load the files. Am İ missing something?
Unlocked, 1.0.2 here
Dragoro
Sep 9, 2007
140
You have to buy your ringtones through iTunes (unless you have modded your phone).
coolie
Sep 18, 2007
131
you need to convert your mp3 to aac then rename it to m4r and sync it over
Jul 23, 2007
205
iPhonebrowser let me put my mp3 ringtones directly onto my iPhone without issue, however this solution only works on 1.0.2. (There's a thread here somewhere about this.)
For 1.1.1 I had to convert and use RingRing which is still a little more work, but doable (and getting better).
