Change icon order?
manishk123
Nov 29, 2007
116
Hi. im a newbie with an unlocked iPhone using firmware 1.0.2 . Just installed the Installer App and then put in 3 more applications including Ilauncher through the Installer.
Now my Ilauncher is the last icon on my home screen. Im afraid if i install any more applications i wont be able to see the ilauncher as it will get pushed down beyond the home screen.
Is there any way to move the icons around? What is the best place to keep Installer and Ilauncher?
Pls help.
iPimp
Nov 12, 2007
60
Not sure about moving them around but once the main screen fills and you get more icons you can move the screen like when web browsing and in settings ( in the installer ) you can have icons show under the dock or do like I do and just turn off dock...;)
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Pls help.
If you are on 1.0.2 you will want to install a program called Summerboard (old). Make sure you get the old one. This program allows the screen to scroll so when you add more icons than can be displayed on the homescreen you can scroll to the other software. 1.1.1 and 1.1.2 have that feature built into them but the older 1.0.2 does not. Summerboard will add that feature for you.
termleech
Sep 7, 2007
1,154
McPherson, KS
Summerboard (old) will let you scroll, Customize will let you change the icon ordering so that you can put them however you want. It also lets you change what icons you have on your dock so you can change them too. Make sure to get either Customize 1.13 or 1.18. Anything in between them is pretty buggy.
manishk123
Nov 29, 2007
116
thanks for all the suggestions guys. Will start out by trying customize.
xSoNiCcRaCkErSx
Jun 30, 2007
226
Don't use customize right now, I don't know what is going on with them but the new versions screwed up my entire M64AP.plist. I suggest you edit this file manually. You can do anywhere from a 3 Icon to a 6 Icon dock maybe even more. To learn how to do this go here: http://www.modmyi.com/forums/showthread.php?t=15988&highlight=dock
termleech
Sep 7, 2007
1,154
McPherson, KS
The new version of Customize (1.18) fixes the issues where it was messing up your MA file. I've never had a single issue with 1.18 and I use it all the time.
smokepsp32
Dec 2, 2007
45
where am i gonna get his one bro?
can you tell me...
thnx
