change SMS alert
wix
Oct 3, 2007
Guys,
I wanna change my sms alert in my iPhone with mp3, is that possible? What should I do? Any software for it? Thanks for the information.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Guys,
In my opinion the easiest way is by using iBrickr. You can find it here with a great detailed video tutorial (Only if you are on firmware 1.0.2 or earlier!):
http://cre.ations.net/creation/ibrickr
Once you follow these steps and run the iBrickr program on your computer there is a tab right on the first page that allows you to change the stock sounds of the iPhone to mp3 sounds of your choice.
Casetay
Jul 29, 2007
45
I use Customize from the AppTapp and just use iBrickr (I use cyberduck for mac) and drop in a few but they have to be in .aif or .wav format
entong
Sep 21, 2007
154
i believe i funtastic can do it also :)
Coldcrazy
Sep 28, 2007
9
when you install a new sound via ibricker does it keep the original or erase it?
Coldcrazy
Sep 28, 2007
9
It replaces the stock sound so you might want to back that sound up on your computer just in case you don't like the new one.
Thanks,Thats what I thought I might have to do.
