Change the In Call Glow Colour!
Stevonw
Sep 14, 2007
560
UK
It seems they folks over at modmyifone.com have done it again, this time deciding to change the in call glow to whatever colour you want!
Please note i take no credit for these, i am only sharing this amazing find.
It's a matter of replacing 2 files
The files are located at:
Please note, there should be no space between the words. It's a mistake on the forum.
Here's some colours for download. Again all credits to the guys over at modmyiPhone.com for these
Light Blue
Dark Blue
Red
Purple
I know that you could already do this with Customize, but with the major problems with Customize and v1.1.1, then i suggest you use this method (remember to backup your original).
Here's an example of what it will do (normally the standard colour is Green)
skiz420
Jul 28, 2007
371
Boston
yes i already had that set up.... so much better than the stock green one... makes the themes look better with it on too
