Change the weather icon
GTB
Sep 2, 2008
Does anyone know how to change the city for the weather?
primsa
Dec 12, 2007
235
Rockford Il.
Press the little "I" in the lower right hand corner. You can add more cities there.
GTB
Sep 2, 2008
I have tried to do that--but it just will not do anything! Quite frustrating- When I push the "i" it looks like it is supposed to launch but it doesn't. I didn't have any problem with changing the time. Anyway, thank you. GTB
dklapsley
Mar 15, 2009
I have the same problem. The little "i" icon in the bottom right-hand corner is inert, does nothing. And this IS very frustrating. If you had any luck with a work-around, drop me note! dklapsley@aol.com
styfle
Mar 31, 2008
3,381
The "i" works for me. Click it and the whole thing flips, click the "+" to add a location.
sinceOS7
Jul 23, 2009
Take the phone outta WiFi mode and go 3g. Then proceed with the "i" ....
"Does anyone know how to change the city for the weather?"
28,365
5,507
Finally...an answer after nearly 11 grueling months of incorrect weather ;)
sinceOS7
Jul 23, 2009
I'm glad I could help. I registered with the solution tonight simply because I couldn't find the remedy ANYWHERE. Seems my own trial and error proves more useful than a lot of these forums....
Spread the info....
