change to SMS bubbles?
TAEWING59
Jul 12, 2008
344
how can i do this... i ssh into my phone downloaded the files but i cant open the .png
emhcee
Apr 4, 2008
246
Try just renaming them to .jpg files, open them and edit, then upon saving rename them back to .png. I've seen that suggested successfuly.
TAEWING59
Jul 12, 2008
344
Okay and how can i delete a file using Fugu because i need to and it just says failure
TAEWING59
Jul 12, 2008
344
and this didn't work...
emhcee
Apr 4, 2008
246
Here's a tip iPhobos provided in another thread:
Go to the download section at www.modmyi.com and there should be a stock icon download. Unzip the files to a folder and photoshop should have no problem opening the images. That is what I did and how I have done all if my mods by using the stock images.
See if that helps?
