Changine permissions?
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I would like to make the following change to the permissions via OpenSSH,
/bin/chmod +s /Applications/StatusStyle.app/StatusStyle
I don't know exactly where to type the command?
Any suggestions?
depthnerd
Feb 16, 2008
1,280
Go into Terminal type in:
shh root@iPhone IP ADDRESS GOES HERE
Then type in your password which is either alpine or dottie, then type in that command. :D
themanofthedark
Jan 5, 2008
2,674
25
Boston
in WinSCP, press PuTTy terminal, and type it in. you can also find the file on your own, press options, and change them yourself.
finally, you can use term-vt100 on the iPhone itself.
depthnerd
Feb 16, 2008
1,280
I typed shh root@ip addr, and got, shh: Command not found.
My bad I put shh, I mean ssh. :p
But you can try and do it on the iPhone with Term-vt100 like he said.
depthnerd
Feb 16, 2008
1,280
For future reference, where do I find term-vt100 through ssh?
Term-vt100 is an iPhone application. It's basically terminal on the iPhone...nevermind that's EXACTLY what it is.
themanofthedark
Jan 5, 2008
2,674
25
Boston
that way, instead of issuing commands from terminal via a ssh connection, you can do them directly from the phone.
it will ask you for password - its alpine. dottie is for 1.0.2 or earlier. m
