Changing background and dock but keep factory icons
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
Hi guys,
What's the easiest way to change the background, status bar and dock but keep the factory Apple icons? I was just going to create a custom theme, but can't find the factory icon set from Apple. Does anyone have the factory icons set out there, or is there another way to do this?
Thank you!
moze
Nov 9, 2007
Hi guys,
Thank you!
in summerboard you have the option to turn off them icons that way you can keep the icons from Apple
connie
Jul 11, 2007
2,839
105
So Cal
I want my dock background transparent but I can't seem to do it with sb or customize. Any suggestions?
15,385
1,089
are you familiar with creating your own themes?
if so, then use this transparent .png as your dock.
i assume customize will do it, but i haven't used it in forever.
connie
Jul 11, 2007
2,839
105
So Cal
Wow, you always know the answers, thanks!
I will try but I am not that familiar in doing this.
connie
Jul 11, 2007
2,839
105
So Cal
For some reason my Customize has the option of changing it to transparent but it won't work when I try to change.
15,385
1,089
you're on a Mac, right?
have you used Cyberduck before?
