changing battery with installer
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
hi im trying to change the battery with installer/apptapp and i cannot find the files that i need to replace....
im not using ibricker..and wont.. im only using apptapp/installer
thanks
antithetic
Jul 9, 2007
69
Do you have 'Show Hidden Files' in MobileFinder set to 'On'?
vtec236
Sep 11, 2007
22
Colorado
It would me nice if someone Zipped all 17 battery icons with energizer overlay
antithetic
Jul 9, 2007
69
Are you trying to put the PNG images in /System/Library/CoreServices/SpringBoard.app/?
I see all the battery PNG files there.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
yes i get there using mobile finder/installer and i don't see any files there?
suggestions .. an i in the wrong place?
jerrettpaul
110
Denton, TX
i found it man. you have to install the new finder, and then go to library on the same page as applications. and its there.
antithetic
Jul 9, 2007
69
The only thing I can think of is a setting in MobileFinder such as "Show Hidden Files" or "System File Access".
jerrettpaul
110
Denton, TX
i have no idea how to do it from my computer. or how to get it back on my phone if i did do it from my computer.
how do you do this?
