Changing text wrapping / width of iPhone SMS text bubbles ?
Riva
May 23, 2008
Hi,
For a long time I have problem with how iPhones native SMS app wraps text in messages.
I usually end up with something like this..
580943d1334834518-changing-text-wrapping-width-iphone-sms-text-bubbles-img_0418-copy.jpg
..which really sucks (and is so lame Apple!) especialy with long sms.
I found screencapst like this on the net..
.. wondered where might be the difference and thought that some tweak might exist for it ?
I tryed to google around it, but no luck so as last resort I decided to ask here.
Be glad for any advice. Thanks
Or alternatively, if you don't know of any mod/fix for this, can you recommend a good 3rd party SMS app ? (preferably with same design as the native one)
TheKrishna
Apr 16, 2012
Don't know about the bubble width, however as for 3rd party SMS I would go with bitesms
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
Yes, I believe the screenshot you found on the net is from a jailbroken app like BiteSMS or iRealSMS due to the different colors of the text bubbles and custom background. I'm not aware of them making the width of texts wider but that may be the case.
Riva
May 23, 2008
The screen is from native iPhone SMS app with some bubble color tweak (from Cydia). Not from 3rd party app.
Riva
May 23, 2008
I just installed BiteSMS (iOS4) and it shows SMS the same as original SMS app. Ie in stupid tall bubbles instead of filling most of the screen width :(
(Help !)
