Changing the dock?
Beyder28
Jul 11, 2007
Can someone please tell me how I can change the dock? I used the search function but could not locate any tutorial that does a step by step on how to change the dock. Thanks.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Proceed w/Jailbreak and iPhoneinterface as normal.
The file you replace is in "/System/Library/CoreServices/SpringBoard.app/" the name of the file is "SBDockBG2.png"
Then back out of jailbreak and iPhoneinterface as normal....
Beyder28
Jul 11, 2007
I'm sorry, I hate to sound stupid but what exactly do I type once I break jail?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
sorry to be simple, but I am on my phone...
If you check out the sticky under the modding section, you can follow any of those tutorials. I personally like the second link listed under the carrier logo change heading.
Let me know if you need more help. Next time I'm on my computer I can give you direct links, but you should be able to figure it out using those tutorials.
fran_lfc
May 8, 2008
19
Hi! I did access the "Springboard" app files, but i can't open them on photoshop or any other application!
styfle
Mar 31, 2008
3,381
theres a zip file on the modmyifone.com site that has all the images on the phone
if you try to pull the png's from the phone you wont see anything
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
SSH into the phone. Then go to /private/var/mobile/Library/SummerBoard/Themes, there you will find all the themes that reside on your phone. You can double click on a particular theme, and you will see Dock.png. Next highlight Dock.png, and from the Aciton menu choose Download To......., Select the folder you want and your done. Simple.
Good luck
