charger only works half the time...
monkeysrock0622
Jul 6, 2007
1,832
27
Marietta, GA
about.me
ok when the first time this happened to me i was freaking out cause i usually only charge my phone when it is close to dead, so i used my old charger for a day or two and then tried the new one again before i got another one. then about a week later, its not working again, on the wall anyways, so i am charging it right now on the computer, but i really need to use it from the wall. can anyone tell me why its doing this? and both times this has happened i checked to see if everything was plugged in ok and made sure there was no dirt or anything blocking the charge port. thanks in advance
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
I've seen people solve this issue with an iPhone restart (Home button and power button)
This resets the charging software in the phone it would seem - worth a try.
RomeoSto
Jul 6, 2007
59
Chicago IL
Have you tried plugging your phone in using a different outlet? If its not the outlet it could be the phone it self.
monstermonkey
Jul 15, 2007
20
I would take it in to an Apple store and have them take a look at it.
had the same problem - drove me nuts. reset didn't fix it but a replacement charger did. i did it over the phone because everytime i took it to the store, the damn charger worked! damn murphy and his laws of nature...
Xtgirl
Jul 21, 2007
32
I was just about to return my charger for this exact problem when it started working again. Was it hard to get them to exchange it over the phone. I guess I will probably wait and see if it stops working again, and if it does try to exchange it. I will always be worried that when I get to the store it will start to work again and make me look like an idiot:(
monstermonkey
Jul 15, 2007
20
i went to the store. looked like an idiot because it worked there. that smug Apple store guy was not friendly. i got on the phone and some nice guy from india (probably) helped me with that request. pretty painless. it was the Apple support number of their website. the nice thing is that you can apparently dial 611 on the AT&T (worst network ever) and get connected to the Apple iPhone support. its all integrated i guess.
Maaz
Jun 30, 2007
584
LA California
yes don't take your wire only take the wall charger, that way they cant check it.
