Charging is not supported with this accessory.
Apr 5, 2011
My iPhone kept showing this "charging is not supported with this accessory" message at times when I charge my iPhone.
What does this means?
Can someone help me? 
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
If you are using an audio dock, it's probably not designed for the iPhone, or it simply doesn't support charging. I have a Tivoli that I use with my iPod nano. Same thing. Works perfectly, but doesn't charge.
Apr 5, 2011
I've always been using the same charger ever since I bought my iPhone. The problem only occurred recently.
I'm charging directly via the power socket.
Seriously, I don't know whats wrong. I switched charger with my friend and it was perfectly fine for her phone.
Apr 5, 2011
Try to do a hard reboot on the phone. hold the power button and home button until you see it shutdown and the Apple show up. After that you can release the buttons. Try it again and see if you still get message.
Just tried, still the same.
Its only when the iPhone is placed at certain "position" then it will charge properly.
But strangely, it doesn't occur on my friend phone. And I can charge properly using my friend's charger.
What's wrong!
