Charging my iPad
mytiabear
Dec 5, 2011
How long is it suppose to take to fully charge an iPad 3? Mine literally takes 24 hours, but I also let it run out to 20% battery life. Is that normal charge time?
RoofMonkey
Jun 21, 2010
8,931
1,983
It does take quite some time to fully charge it. A LOT of battery(ies) in there to juice up. But a full 24 hours does seem a bit long. I drained mine to 5% last night. Plugged it in and left it. Was 100% when I looked this morning around 8am.
glsda
Oct 17, 2007
1,440
50
California
I plug mine directly into a wall plug and it recharges from approximately 30 percent to 100 in approx. 2 hours.
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
If you're using a wall charger 24 hours sounds way too much. I generally can go from zero (letting it fully discharge once a month) to 100% (and a bit extra for the iPad 3) in around 9 hours.
Sharunda
Jun 16, 2008
4,992
1,082
One Horse Town, New Jersey
Yes, I've learned, it charges way faster when plugged directly into the wall. I have mine plugged into a power strip with five slots in it. My iPhone is plugged into it too. Over night I can always get to 100% on both the iPad 3 and the iPhone. I'm usually charging the iPad 3 from 40, 50 or 60% though.
One night I didn't Plug my iPad 3 in like I usually do and when I got up in the morning it was at 63%. I plugged it directly into the wall and within an hour and 1/2 it got up to 100%.
Wall plug is the fastest way! Oh yeah, and use the original USB and plug that came with the iPad 3. If you use the iPhone plug, I don't think you'll get a fast charge and the plug will get hot. The iPad 3 uses a lot of power and the iPhone plug does not provide that power.
N
Normany Clark
Guest
iPad takes 7-8 hour for complete the fully recharge. Your iPad may have problem.
