Charging my phone
Nur2652
Aug 1, 2010
114
My 4 is 27 months old and is dying on me, waiting for the 5 in a few weeks. My phone only charges when it's off I can't get it to charge while on. Any ideas or suggestions? Thanks.
Girdler
Aug 1, 2012
283
44
30
Nur2652 when you say that it charges when it's 'off', do you mean when you put the phone to sleep or lock it? The iPhone's actually do not charge while they're turned off, it will power the device on and then charge it. However, it sounds like it is a software issue. You may need to attempt restoring the device(as new) to test. You can always take it to your nearest Apple store and they can run a diagnostics on it to see if there is an issue with it(no charge even if out of warranty for this test).
