Check This Out!
meiphones_brill
Nov 16, 2007
797
http://www.unlockthatiPhone.com/working.php
it has step by step guides for a lot of things. just search around the site.
and if anyone can confirm that the oob 1.1.2 jailbreak and activate works please let me know
That will do the trick. Things I found:
Leaving the phone at 1.1.1 is fine for the American Cousins - the telephone numbers and stuff are all american - but there are some fixes (stevonw here is one of us even if he is scots, and has the recipe I believe)
Also I like the foreign keyboard options in 1.1.2 and I like my pc not nagging me about upgrading to the latest version.
You'll need to modify that guide because you're not unlocking. Basically:
Get phone in recovery mode
plug into iTunes and force a recovery to 1.1.1 mode
open some tool like the touchfree 1.1.2 jailbreak to get the thing out of recovery
do the *#307* / jailbreakme.com malarkey (this is fun after a while I have done two at once on with each hand)
Install Oktoprep, Then start all over again Updating this time to 1.1.2
Jailbreak again with the touchfree doofer
That's it! - 20 mins tops.
Everything you need is here:
http://conceitedsoftware.com/iPhone/site/112jb.html
Stevonw
Sep 14, 2007
560
UK
The international menu is also available on v1.1.1 (this is the easiest way to achieve UK dialing on a v1.1.1 US iPhone) and also allows you access to the International Keyboards.
All you need is v1.1.1 Jailbroken phone with Installer
1) Add the source "http://i.unlock.no"
2) Let it Refresh the Sources
3) Now choose the unlocking tools folder (under the install tab at the bottom)
4) Choose the "Enable International Menu"
5) After this file has installed, you can instantly access the menu by going back to the springboard and choosing settings, general, international and set your preferences
Hopefully that provides a quick fix to all you v1.1.1 international users :D
Bill Gates
Oct 24, 2007
90
The international menu is also available (this is the easiest way to achieve UK dialing on a v1.1.1 US iPhone) and also allows you access to the International Keyboards.
thanks guys fast reply
wish me luck ill be receiving my 8gb iPhone monday.
meiphones_brill
Nov 16, 2007
797
Weather Icon
On international phones as well the Weather Icon stays stubbornly unchangeable when you customise the look with Summerboard.
I found that it can be easily fixed by modifying the file /Applications/Weather.app/Info.plist
pm me if you want more details - or you may find some other naughty person on the net who has a property list editor and a replacement file.
