Check your iPhone Screen for this
Sep 29, 2007
348
Well I went to the store today for something quite odd. I had "bubbles" in my screen. I posted pictures on here before and everyone was like "its from your old screen its from your old screen!Use GooGone!". Well I got some goo gone and let it sit on there for about 20 mins as it would no come off. Well I ended up going to the Mac Store so they could see what it was.
They were quite confused and saw something quite weird. My iPhone came pre installed with a protective clear shield underneath the plastic that was originally on the iPhone. Kinda confusing but look at it this way:
The iPhone 3G I bought, when it came out of the box it already had a protective shield on it, NOT the plastic covering which you peel away but an adhesive one.
Well they say they have no clue how it would get there but after 5 mins of trying to peel it away we got it. I don't know if thats just a freak manufacturing thing or if its more but if you get "bubbles" in your iPhone that may be it.
Jul 17, 2007
407
baby oahu
that be funny you got a used iPhone... the guy before put a screen protector and didn't use it...
Alexander
Jun 28, 2007
1,724
Atlanta
I bet the screens come precoated with a protective layer before they hit the manufacturing process, and are removed somewhere in the assembly. It somehow missed yours maybe.
k3n85
Jul 14, 2008
90
^^ That would make the most sense, doubt they're repackaging already. Those pretty iPhones don't just pop out in one piece :)
ramesh223
Aug 7, 2008
thanks a lot @Zabumafu for sharing with us....i also have same problem and i can clearly see that a protective shield of some sort is on the touch screen.
I can see the top speaker and bottom button are exposed and the other area is covered with that shield.
I was thinking that the screen has the problems and may be replace it...
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
That is really odd. Alex is probably closest to the reason for the extra screen.
I've actually developed a real bubble under my screen but I am going to wait a while before getting it replaced.
